Looking for direction or documents related to how to load test a grafana setup. I am interested in seeing how many metrics I can push to stack. My initial setup in grafana 5.1.3 and influxdb. Any help or direction appreciated.
Grafana uses data from InfluxDB, so there is not so many metrics related to Grafana performance in this case.
- for InfluxDB benchmarking use https://github.com/influxdata/inch
- there are already blog posts about performance on InfluxDB blog - for example https://www.influxdata.com/blog/the-effect-of-cardinality-on-data-ingest-part-1/
- technical papers if you want to compare InfluxDB with other TSDBs.
Generally, influxdata.com domain is a better place.
Thanks. Some good links there. Appreciate the help.
