Grafana is pausing alerts automatically.
We have logs enabled on application level but not seeing any logs why the alerts getting paused which means grafana is pausing it. can anyone help?
we are using grafana 7.3.4 version.
Hi @maheshchoudhary,
Welcome to the
community support forums !!
A few questions. Is the alerting only use Grafana Server OR do have some other components e.g. Prometheus or alert_manager etc?
If yes, then are those services running without any interruptions on the network?
2nd is that you can increase the grafana log level to debug mode in the grafana.ini configuration file and after the restart, reproduce the issue and observe the logs if they highlight something which may cause this automatic pause/interruptions…
Those will be the initial steps to debug this problem.
