Grafana oss 12.0 log file shows own by root and not updating
Hi Experts,
I am using grafana OSS v12 and I recently I notice that my garafa log files are not updating and it shows log file is own by root. I can see logs in journal and grafana is running as user - grafana.
We are using packer and jenkins to build the grafana.
I changed permission manually for grafana.log file and its getting updated after this but i dont know how this permission on log file is changing.
Any pointer how to troubleshoot this.
  • What happened?
please check
cat /etc/logrotate.d/grafana
o/p : create 0644 root root then
create 0644 grafana grafana
systemctl cat grafana-server
  • User=grafana must be grafana
  • LogsDirectory= ya RuntimeDirectory= config
    check grafana log also
    ls -l /var/log/grafana/
