v10.1.2 / Ubuntu 20.04.6 (using Docker) -
Enable fail2ban to watch for failed login attempts -
I need fail2ban to monitor grafana logs in order to detect failed logins. I know there are logs in /var/lib/docker/containers/, however fail2ban cannot access this location. -
What happened?
Just realized that the grafana logs in /var/log/grafana/grafana.log has not been updated since ~July -
The logs to continue to be updated. -
No errors in grafana logs via portainer.
Grafana in docker container logs to stdout (not to file).
So configure your Grafana in the container log into /var/log/grafana
Then use container volume to map host /var/log/grafana to container /var/log/grafana
I have setup the logs to point to /var/log/grafana and mapped the volume (tried several locations), but the log file never shows.
version: "3"
networks:
proxy:
external: true
services:
grafana:
hostname: grafana
container_name: grafana
image: grafana/grafana:latest
user: "1000"
networks:
- proxy
ports:
- 3000:3000
volumes:
- ./grafana:/config
- ./logs:/var/log/grafana
environment:
- GF_PATHS_DATA=/config/data
- GF_PATHS_LOGS=/var/log/grafana
- GF_LOG_MODE=console file
- GF_PATHS_PLUGINS=/config/plugins
- GF_INSTALL_PLUGINS=grafana-piechart-panel,grafana-worldmap-panel,natel-discrete-panel,grafana-clock-panel
So did you check Grafana logs for any errors?
Blind guess: you have problem with fs permissions so Grafana can’t write into log file.
Or you have some config which overwrites that log config.
It did turn out to be a permission issue since the Grafana container was set to run with user 1000. Was able to get the log file to write now, thank you for the assistance.
