latest -
Access remotely over nginx -
the normal way -
What happened?
No matter how I configure, I get the error{"message":"invalid username or password","traceID":""} -
Got to the login screen -
I have this in the nginx config
location /dashboard/ {
proxy_set_header Host $http_host;
proxy_pass http://127.0.0.1:3000/;
no -
Followed these as best I could Run Grafana behind a reverse proxy | Grafana Labs and Reverse Proxy Grafana with Nginx - Grafana Tutorials
