Grafana not drop the orgid after sign out
I have 2 organizations: The Main Org. (with orgid = 1) and the Visitor (with orgid = 4). A visitor is an organization for viewers without logging in.
If I use grafana without logging in and after I try to log in as a user from the Main Org. I get the error message “Not found”. Refresh page doesn’t help. In the URL I see `/orgid = 4’ and it only helps to change it to ‘/orgid = 1’
my grafna.ini:
[users]
# disable user signup / registration
allow_sign_up = false
# Allow non admin users to create organizations
allow_org_create = true
# Set to true to automatically assign new users to the default organization (id 1)
auto_assign_org = true
# Set this value to automatically add new users to the provided organization (if auto_assign_org above is set to true)
auto_assign_org_id = 1
# Default role new users will be automatically assigned (if disabled above is set to true)
;auto_assign_org_role = Viewer
# Require email validation before sign up completes
;verify_email_enabled = false
# Background text for the user field on the login page
;login_hint = email or username
;password_hint = password
# Default UI theme ("dark" or "light")
;default_theme = dark
# Path to a custom home page. Users are only redirected to this if the default home dashboard is used. It should match a frontend route and contain a leading slash.
; home_page =
# External user management, these options affect the organization users view
;external_manage_link_url =
;external_manage_link_name =
;external_manage_info =
# Viewers can edit/inspect dashboard settings in the browser. But not save the dashboard.
;viewers_can_edit = false
# Editors can administrate dashboard, folders and teams they create
;editors_can_admin = false
# The duration in time a user invitation remains valid before expiring. This setting should be expressed as a duration. Examples: 6h (hours), 2d (days), 1w (week). Default is 24h (24 hours). The minimum supported duration is 15m (15 minutes).
;user_invite_max_lifetime_duration = 24h
# Enter a comma-separated list of users login to hide them in the Grafana UI. These users are shown to Grafana admins and themselves.
; hidden_users =
[auth]
# Login cookie name
;login_cookie_name = grafana_session
# The maximum lifetime (duration) an authenticated user can be inactive before being required to login at next visit. Default is 7 days (7d). This setting should be expressed as a duration, e.g. 5m (minutes), 6h (hours), 10d (days), 2w (weeks), 1M (month). The lifetime resets at each successful token rotation.
;login_maximum_inactive_lifetime_duration =
# The maximum lifetime (duration) an authenticated user can be logged in since login time before being required to login. Default is 30 days (30d). This setting should be expressed as a duration, e.g. 5m (minutes), 6h (hours), 10d (days), 2w (weeks), 1M (month).
;login_maximum_lifetime_duration =
# How often should auth tokens be rotated for authenticated users when being active. The default is each 10 minutes.
;token_rotation_interval_minutes = 10
# Set to true to disable (hide) the login form, useful if you use OAuth, defaults to false
;disable_login_form = false
# Set to true to disable the sign out link in the side menu. Useful if you use auth.proxy or auth.jwt, defaults to false
;disable_signout_menu = false
# URL to redirect the user to after sign out
;signout_redirect_url =
# Set to true to attempt login with OAuth automatically, skipping the login screen.
# This setting is ignored if multiple OAuth providers are configured.
;oauth_auto_login = false
# OAuth state max age cookie duration in seconds. Defaults to 600 seconds.
;oauth_state_cookie_max_age = 600
# limit of api_key seconds to live before expiration
;api_key_max_seconds_to_live = -1
# Set to true to enable SigV4 authentication option for HTTP-based datasources.
;sigv4_auth_enabled = false
#################################### Anonymous Auth ######################
[auth.anonymous]
# enable anonymous access
enabled = true
# specify organization name that should be used for unauthenticated users
org_name = Visitor
# specify role for unauthenticated users
org_role = Viewer
# mask the Grafana version number for unauthenticated users
hide_version = true
@iudinost, this is an interesting issue. I tried to reproduce it on play.grafana.com where we use anonymous access, but when I click on sign in the URL updates to https://play.grafana.org/login.
So I have a couple of questions:
  • What version of Grafana are you using?
  • Does this happen in another browser like Chrome?
  • Are you seeing anything interesting in the browser’s developer tools console?
Yes, sign in is updated to https://play.grafana.org/login to. And after I sign-in as a user from the same organization (OrgID = 4), everything is fine, but if the user is from another organization (the main organization. with OrgID = 1), I get an error Not found and in an url is ..&orgId=4&...
  • Our version is v8.2.5
  • Ya, I can repat it on Google Chrome and Mozilla firefox
  • No
Is there are fix for this? Having the same problem
