Grafana MSSQL variable problem
I want to have a dashboard with templating. The datasource of the dashboad is MSSQL, also known as TQL and the relevant line in the query is this one:
AND GroupName = ‘FullStack’
So the group name is actually a string in the database.
I know want to define a variable $team, so that the user of the dashboard can choose metrics for a specific team by choosing in the dropdown.
My problem is that I did not managed it to use that variable. I’ve tried things like
AND GroupName = $team /* Error here: No such column FullStack*/
AND GroupName = ‘’’$team’’’ /* Empty result where it should not be empty */
So how can I solve this problem?
Try the query as :
WHERE GroupName IN ($team)
Hi, I’ve tried WHERE GroupName IN ($team) and received this error:
“sql: expected 1 arguments, got 0”
before the query was
WHERE GroupName = ‘somevalue’ and it did work, so it seems that this is not an error in the query itself.
How is your variable defined ?
“GroupName” does have multiple values ?
Do you want to be able to filter on multiple GroupNames ?
The variable has the type “Query” which returns values like:
FullStack
Backend
Frontend
Currently the multiple values mode is not active, however it could be useful.
Then define your variable as “Multi-value” and use the provided query above.
You should be able to select it also via the dropdown on your panel and see it filtering your graphs.
That worked now, thank you very much.
