I am trying to query a specific field using Elasticsearch Data source.
I observed that Lucene search is case sensitive.
Is possible to change it to Insensitive. please let me know.
Thanks in Advance!!!
I’m not really sure if I understand your problem. Are you trying to query your specific field but it doesn’t work since you need it to be case insensitive?
Would be great if you could include your query and possibly also the result from the query inspector (you can get the same information with chrome devtools, network traffic and the _msearch request).
Thanks
Marcus
