We would like to send Grafana system logs to our syslog server. However, I need to do it on a non standard port, for example 1518. What would I specify inside of custom.ini to achieve this?
[log]
# Either "console", "file", "syslog". Default is console and file
# Use space to separate multiple modes, e.g. "console file"
mode = syslog
# Either "debug", "info", "warn", "error", "critical", default is "info"
level = info
[log.syslog]
;level =
# log line format, valid options are text, console and json
format = text
# Syslog network type and address. This can be udp, tcp, or unix. If left blank, the default unix endpoints will be used.
;network =
address = 10.10.1.57
# Syslog facility. user, daemon and local0 through local7 are valid.
;facility =
# Syslog tag. By default, the process' argv[0] is used.
;tag =
