Dear All,
Installed Gragana on RaspberryPI 3 B model. After installing, tried to login but no luck.
since its first login to graphana admin & admin credentials has been used and getting following error. Please support.
“Invalid username or password”
Hi reachrao,
What method did you use to install Grafana? Did you follow the installation guide for Raspberry Pi in our docs?
So the login UI appears but admin / admin is not working? Is that an accurate description?
You can use grafana-cli to reset the admin password. Here is a guide:
Thanks for your feedback.
