7.5.6 -
I’m using zabbix as grafana datasource. -
What happened?
I create a dashboard contains about 30 panels to show the device status and internet traffic.
As it shows in the picture, some of the panels can’t loadin successfully, and the dashboard will freeze.
If I try to open another Dashboard, the dashboard can’t load as well. -
it should load the panel value successfully. -
sometimes it shows fetching error.
- Did you follow any online instructions? If so, what is the URL?
no
