Grafana links without reloading the full DOM
Hi, I noticed that when I use links to pass from a dashboard to another, the new dashboard page reloads the full DOM, while when I navigate through grafana itself this doesn’t happen.
Why? there is a way to avoid to reload the full DOM? I noticed this both inserting the link into the panel and using standard way in hmlgraphics panel plugin.
Thanks
@donatod It can be done using locationService which is available in the Dynamic Text panel
Hi hanks. Unfortunatly I’m not able to achieve my scope. Can you please tell me something more about this “locationService”? What is it? Can I use it within javascript code? I need to use htmlgraphic panel. Iwould appreciate if you can give me some more tips.
Thanks so much
