I installed new version of Grafana using brew Install Grafana on macOS | Grafana documentation but it’s not letting me login using default credentials. I’m getting Invalid username or password error
==> Downloading https://homebrew.bintray.com/bottles/grafana-6.2.1.high_sierra.bottle.tar.gz
Already downloaded: /Users/Library/Caches/Homebrew/downloads/bbe7f024db788e3239da2fdbef6e893fee9ad2431e8027d91aa5c55483e17412–grafana-6.2.1.high_sierra.bottle.tar.gz
==> Pouring grafana-6.2.1.high_sierra.bottle.tar.gz
==> Caveats
To have launchd start grafana now and restart at login:
brew services start grafana
Or, if you don’t want/need a background service you can just run:
grafana-server --config=/usr/local/etc/grafana/grafana.ini --homepath /usr/local/share/grafana --packaging=brew cfg:default.paths.logs=/usr/local/var/log/grafana cfg:default.paths.data=/usr/local/var/lib/grafana cfg:default.paths.plugins=/usr/local/var/lib/grafana/plugins
==> Summary
/usr/local/Cellar/grafana/6.2.1: 3,512 files, 170.5MB
210rhtdg:~ $ brew tap homebrew/services
210rhtdg:~ $ brew services start grafana
==> Successfully started grafana (label: homebrew.mxcl.grafana)
Anyone facing this issue?
