Hi Team
Is it possible to integrate Grafana with IBM Bigfix as the data source. We are looking for integration both product so from IBM Bigfix we need to send data to grafana for better reporting and dashboards. If any doc available, pls share. Thanks
I’ve never heard of any integration for IBM Bigfix. Do you know if it can export data in a format that Grafana does have an integration for?
I googled quickly and all I found was a REST API - so it would certainly be possible to build an integration if you are a developer who knows JavaScript.
Hello, i restart the subject, i trying to do Dashboard for bigfix with Grafana.
- first try with direct connection (not succes)
- second try with API Infinity (still in progress)
so if some one can help me or do this before and succes, ping me
