Blue Triangle Integration with Grafana Cloud
Hello Team,
Greetings !
We are trying to achieve Blue Triangle (DEM & Business Analysis Tool) integration with Grafana Cloud, though didnt find any active plugin available under Grafana plugin store.
Anyone worked with this DataSource kindly share your experience that how this is being achieved.
Looking forward on this.
Thank you.
Would it be possible to integrate it with grafana via rest api?
https://help.bluetriangle.com/hc/en-us/articles/360034915953-The-Blue-Triangle-API-Overview
Thank you @yosiasz indeed i went through with this already but majority of API endpoints doesn’t working per expectation.
Used “INFINITY Plug-in “ here for initial testing.
Can you expand on that
