Grafana + InfluxDB + Flux - Query response is different
Hi Team,
I am currently running on Grafana v7.3.6 and using Influx Cloud.
I was trying to set up a dashboard but the data response for the same query is different in the flux script builder and grafana query inspector.
I was able to set up the data-source successfully.
As you can observe in the below screenshots, I am seeing only the first row in the grafana table.
Any help is really appreciated.
Thanks, Sarin
hello !
you can add
|>group () at the end of query to get one table in grafana
grafana transformation can handle that too
