Populate data from TimescaleDB and ElasticSearch based on a field that is present in both data sources.
@vanathinallasivam are you trying to use templating and variables to achieve this? You can use the mixed datasource to mix DBs, as in the photo below. You could then use a transformation to join / filter the data
