Hi Everyone
I am using Grafana API to check the health of datasource via UID but when I am firing the API I am not getting the intended response and getting the error as : 404
full message:
"message": "Not found",
"traceID" : ""
as I can see that in ui datasource is getting created and the button: “save and test” is working fine but still via api it is not working (I have provided all the information correctly double checked it
help would be appreciated
Thanks!
Makes a call to the health endpoint of data source identified by the given uid
. This is not mandatory - every plugin author has to implement support for health checks in their plugin themselves.
Are you sure that used datasource has support for that?
:Hi @varungupta494949,
Welcome to the
community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community
Is your Grafana service running in a containorized Enviornment e.g. Docker, Kubernetes or a local machine?
Hello, I have exactly the same problem. I’m sure I’m using the correct uid.
In my case, my grafana service is running on a local machine.
