Grafana graph panel
#1
Hi am not able to show count on bar graph panel. Is there any way to show Numbers on each bar in graph panel.
Grafana version: 5.2.4
Data source :- Elasticsearch.
#2
can you show us the steps you did ? may be screenshots and what is the error you getting or your gaph and data sample ?
#3
I am not getting any error. i just want to know is there any facility to show number count on each bar graph like i have attached one screenshot but it is different tool
lbarchart
#4
check the query options ? What does it look like I havent tested elastic search as a data source
