9.4.3 - Ubuntu
- What are you trying to achieve?
I have an Elasticsearch datasource with task data, like id, name, priority and status.
I need to show two bars. The first should count all tasks (including all statuses). The second one should show only tasks that are done. Like the image below:
The graph above was made using the old Graph panel. It was made using two queries:
Query A: documentType:"task" AND priorityName:"High"
Query B: documentType:"task" AND priorityName:"High" AND statusName:"Done"
- How are you trying to achieve it?
I’m trying to migrate the panel above to the new Bar Chart panel. But the above solution doesn’t work.
- What happened?
If I use the same two queries, it shows the error Bar charts requires a string or time field.
If I keep only one query, it kinda works, but it shows every status as a separate bar, like below:
Could you guys point me in the right direction?
