10.2 on Windows Server
- What are you trying to achieve?
Time Series Graphs from PRTG
- How are you trying to achieve it?
Using PRTG Plugin, on a windows cloud server with Grafana 10.2
- What happened?
I have managed to get the time series graph, but the data rate (bandwidth) does not match what PRTG is showing.
Grafana time series graph to show the same bandwidth as PRTG
response:"<?xml version=\"1.0\" encoding=\"UTF-8\"?><histdata totalcount="180" listend="1">
20.4.64.1402
12/3/2023 6:05:11 AM
<datetime_raw>45263.2536047569</datetime_raw>
<value channel="Traffic IN (volume)" channelid="2">31 MB
<value_raw channel="Traffic IN (volume)" channelid="2">32537436.0000</value_raw>
<value channel="Traffic IN (speed)" channelid="2">4.34 Mbit/s
<value_raw channel="Traffic IN (speed)" channelid="2">542742.8857</value_raw>
<value channel="Traffic OUT (volume)" channelid="3">2.87 MB
<value_raw channel="Traffic OUT (volume)" channelid="3">3012671.0000</value_raw>
<value channel="Traffic OUT (speed)" channelid="3">0.40 Mbit/s
<value_raw channel="Traffic OUT (speed)" channelid="3">50253.0609</value_raw>
100 %
<coverage_raw>0000010000</coverage_raw>
No Errors, i have set the “Unit” to Bits/sec (SI)
- Did you follow any online instructions? If so, what is the URL?
