Hassio + Grafana v8.0.6 (634112e1d4) -
Have same colors on the legend and on the tooltip -
I was expecting the colors will be taken from the series -
What happened?
Colors are different on the graph vs the tooltip when you hover the graph which is very confusing -
Colors should be the same
Attaching a picture that will show the problem better.
As you can see CO2 Office is green both in the graph and in the legend at the bottom of the graph. Something similar happens for the other measurement CO2 Bedroom. However on the tooltip the colors are switched/changed
Thanks a lot for this great software!
