Grafana Google Oauth Issues behind proxy
I have a Grafana server running behind a reverse proxy. Everything works without issue, except Oauth with Google where I receive a 404 not found error. Once again, everything works without issue. I can log in with local accounts and perform all tasks. When I click the login with Google button is when I get the message. Has anyone else experienced this?
make sure your grafana ini root_url setting is the full root url you use in your browser to access grafana (the reverse proxy url )
Yes, the root_url is set. Keep in mind, everything works perfect except for the Google Login
What is the url it’s redirecting you back to that’s throwing the 404? It should be https://<grafana.yourcompany.com>/login/google
Yes, that is what the log is showing
0400 lvl=info msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=GET path=/ status=302 remote_addr=65.60.173.246:53545 time_ms=0 size=29 referer=
t=2018-04-18T14:03:53-0400 lvl=info msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=GET path=/login/google status=302 remote_addr=65.60.173.246:53545 time_ms=0 size=447 referer=https://grafana.westerville.org/login
t=2018-04-18T14:03:53-0400 lvl=info msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=GET path=/o/oauth2/auth status=404 remote_addr=65.60.173.246:53545 time_ms=1 size=10671 referer=https://grafana.westerville.org/login
Where is the /o/oauth2/auth path coming from? Is that in your Grafana config somewhere?
Yes, in my grafana.ini file I have the following lines under the [auth.google] section
auth_url = https://accounts.google.com/o/oauth2/auth
token_url = https://accounts.google.com/o/oauth2/token
Hmm, I wonder whether your proxy is rewriting the redirect improperly, so Grafana returns a header like Redirect: https://accounts.google.com/o/oauth2/auth?<params> and the proxy is rewriting it to Redirect: https://grafana.westerville.org/o/oauth2/auth?<params> which the browser then follows resulting in the 404.
Yeah, if I manually change the path to accounts.google.com it works. Now, I just have to figure out how to make IIS rewrite work. Maybe it ONLY works if you use a subpath.
The link below had the information that I needed to get this working properly. Just closing the loop for the next person.
