Which technologies grafana uses for frontend and responsive design? does it uses bootstrap?
Thanks
Thanks
It’s a mixture of Angular and React. CSS wise it’s custom but similar to bootstrap in a sense.
Marcus
thanks mefraimsson, both do the same. why both?
Angular is for historical reason and most of the client side are implemented using that. We’ve started migrating away from Angular to React. So there will be two frameworks during the migration time frame.
Marcus
