Hello!
Sorry for my English.
I have 2 datasources of Elasticsearch.
I want to find the number (count) of documents in both data sources that have the same field value.
Hello!
Hi @frostwar,
I believe you can accomplish what you want using the mixed datasource and then using transformations. You’ll need Grafana 7.x or higher.
check out this thread
and this thread
Grafana docs on transformation types
Grafana docs on mixed datasources
I need to match the number of identical values
Have you explored Grafana’s expressions feature? It is still experimental.
It’s not worked for me
чт, 15 апр. 2021 г., 4:25 matt abrams via Grafana Labs Community Forums <grafana@discoursemail.com>:
