Grafana Explore does support highcharts?
Hey members.
I would like query about Grafana explore, doe its supports or allow to use charts that are created using highcharts library using react?
I mean I would like to use highcharts to create custom charts and use that in explore instead of the provided one with grafana? I already created a plugin that leverage highcharts from dashboard.
Any documentation or help related to it would be helpful.
Thanks in advance!
regards,
afridi
