Grafana editors are always in loading state
Hello all,
i am using grafana 8.2.2. i have grafana setup on azure cloud. whenever i try to use some text based editor, it always shows me in loading state. text plugin, jason editor are the example of it.
i wanted to add some panel having simple text in it with text plugin and another use case is to edit panels via jason editor in import dashboard section.
looks like grafana ui dependency is causing the trouble as i am geting errors like “Monaco initialization: error”. all the monaco editors are always shows “Loading…” in UI.
i am not sure how to tackle this problem. weather it is a configuration issue or some other.
it would be grate if anyone can put their brain on it and help.
Thanks.
