Hi guys.
Recently we found this problem:
As you can see, the order on the version code is not correct and, after hours of researching, we almost assure the following points:
- This behaviour is consequence of influxdb (our data source here) and the lack of “order by”.
- With alias by we cannot solve this, please correct me in this point if I’m wrong. Actually we use a $tag_version as alias by.
- The actual order make sense if we think in version as a string.
So, our help request here is, in short, is any workaround that we can use to achieve a correct version code order?
