Grafana v10.0.1 (5a30620b85)
OS : Linux 8 -
I would like to display all instances on 1 dashboard instead of selecting each one
Please advise how to achieve this… any setting on Grafana/query to implement? -
What happened?
Display all instances in 1 dashboard -
Screenshot attached. -
No -
Also, I would like to display the disk space from above dashboard and remove memory usage
it would probably make your dashboard yuuuuge. I added a instance variable including an all value. when choosing all, it will repeat the panel. You will have to make it so that underlying panels filter their individual data by $instance value per instance. Your dashboard is already super busy adding this feature is going to make it pretty hard to parse things out. Wonder if there is a tabs feature in grafana? one tab per instance.
