Hello, we are trying to setup the Grafana-dev environment in a Docker container to test plugin development, and was wondering if there was a proper guide for doing that? We see that there is an official grafana-dev docker image on Docker hub, but that this image does not use the same versioning as the normal grafana image. Is this grafana-dev image supposed to be used for Grafana development, or does it serve some other purpose? Is there a good way to figure out which grafana-dev image to use based on which Grafana version we need to test against?
Related topics
Topic | Replies | Views | Activity | |
How I use Docker for plugin development | 10 | 7970 | March 29, 2022 | |
Plugins with grafana/grafana docker
2 | 11240 | January 13, 2021 | |
Setting up docker based Grafana dev environment | 2 | 2245 | July 15, 2022 | |
How do I create and run a custom panel plugin without using docker? | 2 | 589 | January 24, 2025 | |
Grafana/grafana image vs others | 0 | 1692 | August 17, 2023 |
