Grafana Datasources HA
Hello ,
Good Morning.
I just wanted to know if there is any way to switch Grafana Datasource on condition. As I am using 2 influxDB instances for high availability, both are having same data and are configured in Grafana.if anyone of the influx instance goes down.it will switch the datasource or I need to use some HA loadbalancer?
Check this out
It doesn’t solve your issue, but I just set up a variable in each of my dashboards and allow the user to choose their back-end datasource. If they notice a gap in a chart, they can use the dropdown to switch to my secondary InfluxDB instance.
yes, I thought of the same by creating a dashboard variable and letting users select the datasource through the dropdown.
