Good morning to all,
I have some custom grafana graphs like this:
As you can see in attached image, i use tag alias to show values classified by this tag.
Problem is that when a tag key has no longer exists (has no already values), grafana graph shows next message “Data points outside time range”
I have tried to remove tag key from influxdb database with no more values, but it doesn´t work.
Do you know any solution or workaround to fix problem or hide this message from graph?
Any help would be appreciated.
Thanks in advance.
Regards,
Alberto M.
