Grafana dashboard source control
Dear All,
Can you kindly suggest recommendations on how I can source control the dashboards/ definitions? I agree Grafana has it’s own version control but we wanted to have our own version into an external source code management system. There are 100+ dashboards - is there an easy way to get definitions/ JSON directly from Grafana server?
Thanks
Grafana API is your friend. You can use a simple bash scripting or more or less sophisticated nodejs/golang/… libraries.
IMHO the most professional option is Terraform Grafana provider - you can provision Grafana datasources/dashboards/alert notifications as “a code”.
Awesome, worked like a charm! Thanks @jangaraj! This was sooooo handy
Cheers
how did u do , i have a lot of dashboard to and i want to have likn with git repo to store my dashboard in json format but in my conf files for dahsboard in grafana provisionning can i directly give a link on path section ?
