What Grafana version and what operating system are you using? 9.1.7
What are you trying to achieve? I am trying fetch the jmeter values that stored influxdb
How are you trying to achieve it? I used an external JAR in jmeter to send the responses to influx db (Apache JMeter - User's Manual: Component Reference)
What happened? I was able to send the data to influx db but when I try to fetch the data to a grafana dashboard it ends up with an error -
What did you expect to happen? for the data in the influxdb to show up
Jmeter -
Grafana -[Apache JMeter Dashboard using Core InfluxdbBackendListenerClient | Grafana Labs]
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. - Regex errors as shown above
Did you follow any online instructions? If so, what is the URL? No
