Basically there’s a task where i need to make sure that Alert would only trigger between certain hours or days.
for example Triggering an Alert only if it’s a Weekday - basically having the ability to Schedule - Now Reporting feature within Grafana does not provide this feature.
So was hoping if anyone of you have come up with a solution incase you faced this problem
its something similar to topic below but Reporting feature does not solve the problem. Reporting only sends out reports what we are trying to control is “Alerts”
