Hi ,
I have a custom variable “x” … Now based on the value of some other variable ( y) , I would like the populate “x” …E.g if “y” == 1 , then x = 0
And if “y” == 0 , then x = null;
Is such conditional logic possible in Grafana ?
Hi ,
No Grafana does not allow direct if-else logic between variables in the variable settings.
But we can use a workaround using a query variable with PostgreSQL.
You can you this approch mention in steps
y
x
x
SELECT CASE
WHEN '${y}'::int = 1 THEN '0'
WHEN '${y}'::int = 0 THEN NULL
END AS x;
This will make x
return:
0
when y = 1
null
when y = 0
Type: Custom
Values: 1,0
This will create a dropdown so you can choose between 1
or 0
x
In your panel queries, just use ${x}
like this:
SELECT *
FROM my_table
WHERE some_column = ${x}
You could do a trick with custom values using infinity csv key values
y would be represented simply as
1
0
x would be represented as
__value,__text
1,0
0,null
then you use filtering mechanism, when y changes update x based on the value of y that matches __value
column of variable x
in this case __value
represents the value of y so you are creating a relationship
