By default it appears that standard http calls such as the simple example below log the Authorization header and are visible in the logs section of the dashboard.
The logs include source=http-debug.
This appears to be the default behaviour.
Is there any way of turning off http debugging specifically in the synthetic monitor scripts.
Using
export const options = {
httpDebug: ‘none’
does not work. The documentation implies httpDebug:’full’ is not the default however it does appear to me to be.in the context of synthetics.
Note - I appreciate in the example below you could use k6/secrets - however that does not resolve the problem as in subsequent calls the auth token generated also appears in the logs.for subsequent requests.
Hi @michaelodriscoll , thanks for flagging this. We’ve received similar reports from others and have a a voice-of-customer issue open for it. I don’t have an ETA on a fix, but we are looking at
making the `httpDebug` option configurable in the scripts (it is currently hardcoded to httpdebug=”headers”)
It’s possible to workaround the issue with a private probe, where you can set the K6_HTTP_DEBUG environment variable, which overrides the hardcoded CLI flag in the probe agent. For example with docker:
docker run -e K6_HTTP_DEBUG='' grafana/synthetic-monitoring-agent --api-server-address=${API_SERVER} --api-token=${API_TOKEN} --verbose=true
I’ve just hit this issue too. Any news on a solution that doesn’t require running private probes? I know ETAs can be tricky but it would be great to know if this is being actively worked on now.
If you have generated auth tokens showing up in headers, how about an adaptive logging drop rule? It might be worth trying in the meantime as a workaround.
For example I set this rule up to drop any synthetics logs that contain a basic auth header:
