Grafana CheckMk Plugin
Hi Team,
We have use case where we want to send data to either to Prometheus or OTEL collector via Grafana Check_mk Plugin , is it a possibility ?
or is it a possibility if Grafana itself can send data to Prometheus or OTEL collector?
The grafana plugin for checkmk allows you to visualize your checkmk data in grafana, it doesnt send it anywhere. the checkmk agent is the equivalent of prometheus or otel, you dont need all of them
Thanks for your quick reply .
