Grafana agent with prometheus (on premise)
hello guys
i have been wondering if there is a way to connect Grafana Agent with Prometheus (on premise - not enterprise) ?
I can see that metrics have to been send by “remote_write” to the grafana cloud, i cant find any informations about sending them to the on-premise database.
/Tom
Hello :wave: and welcome to the forum, @todb
Agent is really meant as a solution for Grafana Cloud. If you are running your own Grafana, then there should be a simpler method. What are you trying to monitor or instrument? Do you have prometheus metrics exposed on some endpoint for Prometheus to scrape?
By design, Prometheus uses a pull method, not a push method.
thanks its sorted now! :slight_smile:
I just created a working sample on
Regards,
