I am new to both Loki and Grafana and we are using both in a docker compose. The problem I have is that Grafana can’t seem to connect to Loki. My docker compose file is as follows:
services:
loki:
container_name: loki
image: grafana/loki:main
ports:
- "3100:3100"
volumes:
- ./loki/loki-config.yaml:/etc/loki/local-config.yaml
command: -config.file=/etc/loki/local-config.yaml
grafana:
container_name: grafana
image: grafana/grafana:11.6.0
environment:
- GF_AUTH_ANONYMOUS_ORG_ROLE=Admin
- GF_SECURITY_ADMIN_PASSWORD=admin
- GF_AUTH_ANONYMOUS_ENABLED=true
- GF_AUTH_BASIC_ENABLED=false
ports:
- 3000:3000/tcp
depends_on:
- loki
entrypoint:
- sh
- -euc
mkdir -p /etc/grafana/provisioning/datasources
cat <<EOF > /etc/grafana/provisioning/datasources/ds.yaml
apiVersion: 1
datasources:
- name: Loki
type: loki
access: proxy
orgId: 1
url: http://172.19.0.2:3100
basicAuth: false
isDefault: false
version: 1
editable: false
EOF
/run.sh
Both containers start fine and the IP Address for Loki is correct, but when I use the Grafana and I test the data source, it can’t connect.
Any ideas greatly appreciated.
Thanks
Michael
