Grafana bug or?
Hi, I am using the latest version of Grafana v9.3.0
Afther update i see now that my year notation has changed
I get now the year (2022 m³)
See my image for expanation
Anny suggetions ??
Try givingthose columns actual aliases
For the first field of max do
as _value
And for the year column do
as _year
And in the x axis use _year
And see what happens
Thanks Yosiasz for your reply but it wont give me any result.
When i use the underscore like in your example i can only see the result in table form
I did use it witout the underscore so i coult select x-axis as Year
But also no result.
This is my database not special i think.
Yes that is it.
I had choose cubicmeter when change it to number …eureka
But now my legend dont give me cubicmeters
Another query where i group by month it give me not this cubic meter behind the year notation
legend where it says gasverbruk?
No, I mean the Y-axis there you miss the designation cubic meter. I think it’s a bug, but nevertheless I found a solution that I can live with.
See picture
Y axis? I see cubic meter there. Do you mean X axis where the year is?
