Grafana behind reverse proxy (nginx) with subpath
Thanks, but this unfortunately does not help me. The intended issue behind the question is that I’d like to redirect things like example.com/foo/grafana and example.com/bar/grafana to separate Grafana instances using reverse proxy. So if there is no civilized way to do the redirect, I need to think of a different solution.
And where is a problem?
nginx:
  location /foo/grafana {
    proxy_set_header Host $host;
    proxy_pass http://foo-grafana:80/foo/grafana/;
  location /bar/grafana {
    proxy_pass http://bar-grafana:80/bar/grafana/;
foo grafana:
[server]
http_port = 80
domain = localhost
root_url = %(protocol)s://%(domain)s:%(http_port)s/foo/grafana/
serve_from_sub_path = true
bar grafana:
[server]
http_port = 80
domain = localhost
root_url = %(protocol)s://%(domain)s:%(http_port)s/bar/grafana/
Of course some testing and minor polishing may be needed - these are not copy&paste, 100% valid configs.
Yeah, thanks, I’ll likely end up with something like this.
