Im using Grafana version 9.0.4 on Ubuntu in Azure. -
I’m trying to give authenticate to another AWS Organization with IAM Role anywhere, the new feature.
- How are you trying to achieve it?
I followed this blog: Extend AWS IAM roles to workloads outside of AWS with IAM Roles Anywhere | AWS Security Blog (amazon.com)
I put the external authentication method in .aws/credentials file.
What happened?
It doesn’t seem to work, even though I put 0644 permissions in the credentials file. -
I expected for the authentication to work.
- Can you copy/paste the configuration(s) that you are having problems with?
Everything is in the blog post
Was anyone able to make it Grafana work with IAM Role anywhere? thanks!
