Grafana and Jaeger - 502 bad gateway - connection refused
  • v8.2.0 (d7f71e9eae) running in docker on Windows 10.
Connect Jaeger as a data source after the initial install of Grafana.
I am filling out the Jaeger data source dialog. I enter http://localhost:16686 and click on Save and Test.
  • What happened?
The following is displayed in the data source screen. Jaeger: Bad Gateway. 502. Bad Gateway shown in browser
In the docker image for grafana I can see a connection refused message
t=2021-10-11T01:34:53+0000 lvl=eror msg=“Data proxy error” logger=data-proxy-log userId=1 orgId=1 uname=admin path=/api/datasources/proxy/3/api/services remote_addr=172.17.0.1 referer=http://grafana.staged-by-discourse.com/datasources/edit/xCVWnQv7k error=“http: proxy error: dial tcp 127.0.0.1:16686: connect: connection refused”
Both Jaeger and Grafana are running in docker on the same machine as I am on. All localhost. I can connect to Jaegar in the browser and I can connect to Jaegar via powershell without error on the same computer hosting the docker images.
Invoke-WebRequest -uri http://127.0.0.1:16686
I can also connect using c#
        WebClient wc = new WebClient();
        string data = wc.DownloadString("http://localhost:16686");
But Grafana does not seem to be able to connect to the Jaegar instance. Grafana is running on localhost on port 3000
It should connect without error.
No configuration changes made except trying to add the data source.
t=2021-10-11T01:34:53+0000 lvl=eror msg="Data proxy error" logger=data-proxy-log userId=1 orgId=1 uname=admin path=/api/datasources/proxy/3/api/services remote_addr=172.17.0.1 referer=http://grafana.staged-by-discourse.com/datasources/edit/xCVWnQv7k error="http: proxy error: dial tcp 127.0.0.1:16686: connect: connection refused"
t=2021-10-11T01:34:53+0000 lvl=eror msg="Request Completed" logger=context userId=1 orgId=1 uname=admin method=GET path=/api/datasources/proxy/3/api/services status=502 remote_addr=172.17.0.1 time_ms=1 size=0 referer=http://grafana.staged-by-discourse.com/datasources/edit/xCVWnQv7k
t=2021-10-11T01:41:58+0000 lvl=eror msg="Data proxy error" logger=data-proxy-log userId=1 orgId=1 uname=admin path=/api/datasources/proxy/3/api/services remote_addr=172.17.0.1 referer=http://grafana.staged-by-discourse.com/datasources/edit/xCVWnQv7k error="http: proxy error: dial tcp 127.0.0.1:16686: connect: connection refused"
t=2021-10-11T01:41:58+0000 lvl=eror msg="Request Completed" logger=context userId=1 orgId=1 uname=admin method=GET path=/api/datasources/proxy/3/api/services status=502 remote_addr=172.17.0.1 time_ms=1 size=0 referer=http://grafana.staged-by-discourse.com/datasources/edit/xCVWnQv7k
2 days and no replies - any idea how I debug this issue?
localhost in the container is not localhost on the host. Each container has own network namespace (so also localhost) + it probably more complicated from the network perspective, because you are running Docker on windows - and that Docker is running on Linux VM usually. Generally, don’t use localhost, but hostname/IP (not 127.X.X.X - that’s localhost IP).
