Hi, i have a problem with my stage.timestamp in grafana alloy, here is my configuration:
local.file_match "tomcat_logs" {
path_targets = [{
__address__ = "ibiatap01",
__path__ = "/opt/tomcat_a/logs/webapps_blue/analytics/main.log",
app = "analytics",
environment = "blue",
job = "tomcat",
__path__ = "/opt/tomcat_a/logs/webapps_green/analytics/main.log",
app = "analytics",
environment = "green",
job = "tomcat",
loki.process "tomcat_logs" {
stage.regex {
expression = "\\[(?P<tenant>[^\\]]*)\\]\\*? (?P<time>\\d{4}-\\d{2}-\\d{2} \\d{2}:\\d{2}:\\d{2}.\\d{3}); (?P<thread>[^;]+); \\[(?P<level>[^\\]]+)\\]; (?P<component>[^;]+); (?P<message>.+)"
stage.multiline {
firstline = "\\[(?P<tenant>[^\\]]*)\\]\\*? (?P<time>\\d{4}-\\d{2}-\\d{2} \\d{2}:\\d{2}:\\d{2}.\\d{3}); (?P<thread>[^;]+); \\[(?P<level>[^\\]]+)\\]; (?P<component>[^;]+); (?P<message>.+)"
stage.labels {
values = {
tenant = "tenant",
thread = "thread",
level = "level",
component = "component",
time = "time",
stage.timestamp {
source = "time"
format = "2006-01-02 15:04:05,999"
forward_to = [loki.write.default.receiver]
loki.source.file "tomcat_logs" {
targets = local.file_match.tomcat_logs.targets
forward_to = [loki.process.tomcat_logs.receiver]
loki.write "default" {
endpoint {
url = "http://10.221.9.61:3100/loki/api/v1/push"
external_labels = {}
livedebugging {
enabled = true
Everything works correctly if i don’t add the stage.timestamp setted. when i set it, is like alloy is not able to detect the format of the rows of the log. I’m sure that the regex is correct because i checked with regex101: build, test, and debug regex and i douboled all the \ like wrote in the documentation of alloy. Here following there are some example of logs that i want to detect:
- log with tenant defined single line
[tenant.test]* 2025-03-18 08:44:49,192; ajp-nio-0.0.0.0-8010-exec-2; [ERROR]; HeadTag; com.agency.IA.dispatchers.actiondescriptor.internal.IASessionExpiredException: IASessionExpiredException - Instance not found, need redirect to login page
- Log with tenant not defined:
[]* 2025-03-18 08:44:49,192; ajp-nio-0.0.0.0-8010-exec-2; [ERROR]; HeadTag; com.agency.IA.dispatchers.actiondescriptor.internal.IASessionExpiredException: IASessionExpiredException - Instance not found, need redirect to login page
- Log without the ‘*’
[tenant.test] 2025-03-18 08:44:49,192; ajp-nio-0.0.0.0-8010-exec-2; [ERROR]; HeadTag; com.agency.IA.dispatchers.actiondescriptor.internal.IASessionExpiredException: IASessionExpiredException - Instance not found, need redirect to login page
- Log multiline with stack trace, that need to be detected as 1 single log (the first line could match one of the pattern shared before):
[]* 2025-03-19 06:00:08,767; Timer-0; [WARN]; MainLogger; Generic error occurred at 06:00:08 303ms Wednesday 19 March originating thread process_24.0xxx for user CPContext of user:5.0 guest:false company:xxx username to be determined instance: pippo.test last accessed:Wed Mar 19 06:00:08 CET 2025 with stacktrace:java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at iacl_fspace_statsR.Page_4(iacl_fspace_statsR.java:475)
at iacl_fspace_statsR.Page_1(iacl_fspace_statsR.java:364)
at iacl_fspace_statsR.Run(iacl_fspace_statsR.java:520)
at iacl_fspace_statsR.Run(iacl_fspace_statsR.java:505)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
And there are also line that should be catched as multiline that are like the log line before but after that a stack trace that don’t match the regex.
I really need and help to undestrand what is the problem of the stage.timestamp because my goal is to map the time extracted from the log line to the time of the log line in grafana e loki
