Grafana Alloy - Memory Usage
I have setup my Grafana Alloy, Loki to successfully take the logs from my Application. However, I see one problem that I couldn’t find anywhere to solve.
The problem is my Grafana alloy container is taking up a lot of memory(like 742MiB), even though other containers such as Grafana(77MiB), Loki(64MiB), Prometheus(125MiB) are taking a much less memory compared to Alloy. Is there a way to reduce the memory usage that Alloy is taking up?
Does it have to do anything with Log format, the way container is started, or the way that the configuration file that is written?
Alloy Service
alloy:
    image: grafana/alloy:latest
    container_name: alloy
    volumes:
      - ./config.alloy:/etc/alloy/config.alloy
      - /home/abhishek/Documents/logs:/var/log/app-logs:ro
    command:
      - run
      - --server.http.listen-addr=0.0.0.0:8083
      - --storage.path=/var/lib/alloy/data
      - /etc/alloy/config.alloy
    depends_on:
      - loki
    networks:
      - grafana-network
My config.alloy
local.file_match "log_files" {
  path_targets = [{"__path__" = "/var/log/app-logs/*/*.log"}]
  sync_period = "5s"
local.file_match "log_gz_files" {
  path_targets = [{"__path__" = "/var/log/app-logs/*/*.log.gz"}]
  sync_period = "5s"
loki.source.file "file_source" {
  targets = local.file_match.log_files.targets
  tail_from_end = true
  forward_to = [loki.process.log_processing.receiver]
loki.source.file "file_gz_source" {
  targets = local.file_match.log_gz_files.targets
  decompression {
    enabled = true
    initial_delay = "10s"
    format = "gz"
loki.process "log_processing" {
  stage.json {
    expressions = { "level" = "level", "time" = "timestamp"}
  stage.regex {
    expression = "/var/log/app-logs/(?P<service>[^/]+)/.*"
    source = "filename"
  stage.labels {
    values = { "loglbl" = "level", "service_name" = "service" }
  stage.timestamp {
    source = "timestamp"
    format = "RFC3339"
    action_on_failure = "skip"
  forward_to = [loki.write.loki_receiver.receiver]
loki.write "loki_receiver" {
  endpoint {
    url = "http://loki:8082/loki/api/v1/push"
how big are those gz files and how often you get new ones
same with the other files?
There is only one new .log file which is created for today, and there are older 29 days of gz log files. When a day passes by, today’s log file gets zipped out…
gz files size depends on the number of logs generated for that day(ranging between 20KiB-250KiB).
There are people using the application, so I say the logs get generated so often.
But, there is some time when people don’t use the applications, during that time too the memory and CPU doesn’t go down.
It seems that the memory resource that alloy is taking is gradually getting increased day by day.
The first message when I stated, the memory info was 742MiB, now it is being 5.2GiB.
Could anyone, please help me fix this problem?
