Grafana Alloy cannot correctly parse log filenames for reading
I configured the grafana alloy to sending openshift log. This is my configuration:
// 1. Discover Kubernetes Pods
      discovery.kubernetes "pods" {
        role = "pod"
      // 2. Relabel metadata + build log path
      discovery.relabel "pod_logs" {
        targets = discovery.kubernetes.pods.targets
        rule {
          source_labels = ["__meta_kubernetes_namespace"]
          regex         = "ns-test"
          action        = "keep"
        rule {
          source_labels = ["__meta_kubernetes_pod_container_name"]
          regex         = "istio-.*"
          action        = "drop"
        rule {
          source_labels = ["__meta_kubernetes_namespace", "__meta_kubernetes_pod_name", "__meta_kubernetes_pod_container_name", "__meta_kubernetes_pod_container_id"]
          separator   = ";"
          regex = "^(.+);(.+);(.+);.+://(.+)$"
          replacement = "/var/log/containers/$2_$1_$3-$4.log"
          target_label = "__path__"
        // Namespace
        rule {
          action = "replace"
          target_label  = "namespace"
        // Pod name
        rule {
          source_labels = ["__meta_kubernetes_pod_name"]
          action = "replace"
          target_label  = "pod"
        // Container name
        rule {
          action = "replace"
          target_label  = "container"
        // Node name
        rule {
          source_labels = ["__meta_kubernetes_pod_node_name"]
          action = "replace"
          target_label  = "node"
        // Drop Alloy self logs (tránh loop)
        rule {
          regex         = "alloy.*"
          action        = "drop"
      // 3. Read log files from node
      loki.source.file "pod_logs" {
        targets    = discovery.relabel.pod_logs.output
        forward_to = [loki.process.parse.receiver]
      // 4. Parse CRI log format
      loki.process "parse" {
        stage.cri {}   // CRI-O compatible (OpenShift)
        forward_to = [loki.write.loki.receiver]
      // 5. Send logs to Loki Distributed
      loki.write "loki" {
        endpoint {
          url = "http://loki-distributed-gateway.observability.svc.cluster.local/loki/api/v1/push"
          tenant_id = "prod1"   // bỏ nếu không dùng multi-tenant
I am getting the problem when Alloy cannot read correctly file name.
no such file or directory" key="{Path:/var/log/containers/app-520ab14b83af58fc8556522f4fa79c4238acbf7c0cc28d5cd55cee1203fd853a.log
Are you running alloy in a container? If so, make sure you are mounting /var/lib/docker/containers from host to Alloy container.
If you are running alloy directly on the host, make sure Alloy user has permission to see the /var/lib/docker/containers directory.
I am running in k8s (OCP)
Make sure the container logs directories are mounted to Alloy. You can reference the community k8s-monitoring helm chart.
