Alloy not sending logs to loki
Im working on installing Alloy to a test cluster as a replacement for Promtail. I have attached the allow config I generated and tweaked from my old Promtail config
As near as I can tell, it looks like my local.file_match.pod_logs is not discovering any valid targets from the path_targets argument being passed.
I have confirmed several of the “__ Path __” targets DO indeed have log files to be found on the same node but the ‘targets’ export remains empty.
Ive set logging to ‘debug’ and not seeing any helpful information
It seems like this component should ‘just work’?
alloy.json (3.8 KB)
Solved. I had not set the helm chart values to include the volume mount for /var/logs.
