Alloy on OpenShift: loki.source.file can’t see /var/log/pods logs
I’m running Grafana Alloy on OpenShift (deployed via Helm) and trying to collect pod logs with loki.source.file.
Note : Applied the node-exporter scc to service account
alloy.yaml
kind: Alloy
metadata:
  namespace: test
spec:
  controller:
    type: daemonset
    tolerations:
      - effect: NoSchedule
        operator: Exists
    volumes:
      extra:
        - name: alloy-client-cert
          secret:
            secretName: alloy-client-cert
  serviceAccount:
    create: false
    automountServiceAccountToken: true
  rbac:
    create: true
  alloy:
    mounts:
      varlog: true
    securityContext:
      runAsUser: 0
      runAsGroup: 0
      fsGroup: 0
    configMap:
      create: false
      key: alloy-val
    storagePath: /var/alloy
configmap;
apiVersion: v1
kind: ConfigMap
metadata:
data:
  alloy-data: |
    logging {
      level  = "debug"
    local.file_match "pod_logs" {
      path_targets = [
        { __path__ = "/var/log/pods/*/*/*.log" },
    loki.source.file "pod_logs" {
      targets    = local.file_match.pod_logs.targets
      forward_to = [loki.write.victorialogs.receiver]
    loki.write "victorialogs" {
      endpoint {
        url        = "<url>"
        tenant_id  = "0:0"
      external_labels = {}
But in Alloy logs I see:
ts=2025-09-22T23:19:50.679821972Z level=debug msg="no files targets were passed, nothing will be tailed" component_id=loki.source.file.pod_logs
What’s the recommended way to collect pod logs with Alloy in OpenShift?
why not getting log data?
  1. First I would verify that /var/log from host is actually mounted in your Alloy container and that you can see the content of /var/log from within the container.
  2. You can use double asterisks to match multiple directory paths, for example:
      path_targets = [
        { __path__ = "/var/log/pods/**/*.log" },
thank you. corrected the mount . its working now
