Alloy targets are not updating when the pod ID changes. Since logs are being read from a PVC path mounted on the node, the changing UID causes Alloy to miss the new pod logs. As a result, Alloy is not scraping logs from the new pod. How can this be fixed?
With this component: local.file_match | Grafana Alloy documentation it will continue to check the filesystem for new files. See examples in docs, they can help too.
I tried issue still persist.Alloy initially tails logs correctly because Pod UID and paths exist.
When the pod restarts:
Pod gets a new UID
The kubelet directory path changes (/var/lib/kubelet/pods/<NEW_UID>/volumes/…/logs/…)
Alloy does not update its targets — it keeps looking for old Pod UID paths
Any suggestions?
Here is an example how to construct a path using discovery.kubernetes which will keep the pod IDs in-sync.
discovery.kubernetes "k8s" {
role = "pod"
discovery.relabel "k8s" {
targets = discovery.kubernetes.k8s.targets
rule {
source_labels = ["__meta_kubernetes_namespace", "__meta_kubernetes_pod_label_name"]
target_label = "job"
separator = "/"
rule {
source_labels = ["__meta_kubernetes_pod_uid", "__meta_kubernetes_pod_container_name"]
target_label = "__path__"
separator = "/"
replacement = "/var/log/pods/*$1/*.log"
local.file_match "pods" {
path_targets = discovery.relabel.k8s.output
loki.source.file "pods" {
targets = local.file_match.pods.targets
forward_to = [loki.write.endpoint.receiver]
loki.write "endpoint" {
endpoint {
url = "<LOKI_URL>"
basic_auth {
username = "<USERNAME>"
password = "<PASSWORD>"
I also recommend the k8s-monitoring helm chart which makes it much easier to deploy a pipeline that works.
